Help with modifying bevel edge
anisamariam180
Message 1 of 8
anisamariam180
Hi everyone!  I am new to Fusion 360.  Hoping someone can share their expertise on the following:  I have imported an object into Fusion 360 from another program.  The object has a curved edge with a bevel (see attached image).  I need to modify the bevel to make the angle more gradual, as shown.  Any suggestions?   Appreciate any help.
Replies (7)
Message 2 of 8
g-andresen
1. turn on the design history > delete the unwanted fillets and create new ones
2. please share the file
File >Export > save as f3d on local device > attach to next post
günther
Message 3 of 8
anisamariam180
Hi, thanks for quick reply.  Attached is the file.
Message 4 of 8
g-andresen
much easier:
Since it's a Msh body, it's easier to create a new sketch > extrude the profile > create "your smooth fillet".
günther
Message 5 of 8
anisamariam180
Thanks, I will give it a try.  I may need to find a basic tutorial on creating a flat shape with bevel edge.  Not sure if a curved edge makes it more difficult or not.  Will try,
Message 6 of 8
jhackney1972
This model will probably take a little bit of tutorial study to get the information you need and it will not be in one tutorial.  I have created a Screencast showing you the process of modeling the part.  I had to guess at the dimensions as it is very hard to pull accurate dimensions from a STL file.  When you create your model, you can enter the dimensions you desire.  My model is attached.  It is important you use it as a learning tool and create your own and by all means, please go to the tutorials and use them to learn Fusion 360.
By the way, I created this model one way, there are other ways.  Choosing the one that suits your style and needs is always important.
John Hackney, Retired
Message 7 of 8
anisamariam180
Wow!  This is an awesome lesson, which will save me lots of time trying to figure this out.  I will go through these steps to create the part.  Thanks so much for the help!  Such a great forum for learning these tips.
Message 8 of 8
TheCADWhisperer
@anisamariam180
Attached is an alternative using the BORN Technique...
