Link Sketches between different designs
manolo.dev
manolo.dev
Hello, I wonder if there is a way to link only sketches to another design, so if I change the original the other design will reflect the changes.
etfrench
Insert Derive will allow you to share a sketch between files.  You can modify the sketch in the original file and it will update in the new file.
You can also just put the sketch in a file, then import that file into the new file.  You can then either edit the original or use the Edit In Place command in the new file.
ETFrench
