Help with Holes
Help with Holes
Message 1 of 24
Help with Holes
So I have a hole cut out into this Valve Cover, but I need it to wrap around with a lip. I hope the screen shot explains better what I'm trying to do.
Replies (23)
Message 2 of 24
HughesTooling
Use plane along path to create a plane at one end the sketch your profile and sweep. Or maybe a simple pipe feature might work.
Something that might cause a problem is the line here
Are the 2 diameters different, is there supposed to be a join here or do you have a mismatch error?
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 24
lichtzeichenanlage
Can you File -> Export your design and upload it here? Otherwise it's just a guessing game. One guess based answer could be:
  • Create a sketch on the flat surface
  • Sketch -> Project / Inlcude -> Project the hole into that sketch
  • Offset that projection to the desired thickness
  • Close the profile by using lines
  • Close the sketch
  • Extrude the profile to the desired length
Message 4 of 24
When I get home this evening I will export the file to see if what your talking about can help, cuz i also need help to create a valley on particle line. I will the file this evening.
Message 5 of 24
Will this work?
https://a360.co/2Oi6fRZ
Message 6 of 24
TheCADWhisperer
@Anonymous wrote:
Will this work?
Attaching the file directly here works even better.
Sketch1 is not fully defined.
Message 7 of 24
Here is a DXF file, i hope this will work till I get home.
Message 8 of 24
TheCADWhisperer
Why did you Attach this dxf file?
Message 9 of 24
I have no clue what I'm doing and I'm doing this from my work computer....sorry.
Message 10 of 24
chrisplyler
Message 11 of 24
I will attempt to do this when I get off work, but I'm not sure I'm that skilled but I will try.
Message 12 of 24
chrisplyler
Just copy my steps from the video. Pause the video as necessary and go one step at a time. After you've done it once, you realize that it's easy.
Message 13 of 24
lichtzeichenanlage
Thx for screencasting my guessed steps. I was low at time.
Message 14 of 24
Thank you so much, worked perfectly. I have one last thing I need a groove cut out on this line, the line is the center line. How do i get it to cut a groove for like a gasket for example.
Message 15 of 24
chrisplyler
You will notice that I get errors when trying to Sweep the groove into the shaft opening. I don't know why. But no problem, I just use a Revolve instead.
Message 16 of 24
lichtzeichenanlage
Here is my version. Just for educational reasons I've removed your design and just kept the first sketch. You've used to many unnecessary steps and some features that are not needed. If you now would finally fully define your sketch by creating dimensions and constrains until all the sketch lines are black your design would be much more robust to changes.
Message 17 of 24
lichtzeichenanlage
I've missed to attach the export.
Message 18 of 24
michallach81
Without getting into why few things should be done differently, one tip might be useful, to utilize geometry we already have:
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
Message 19 of 24
lichtzeichenanlage
Jip, I was thinking about this, too. I didn't picked this solution because my assumption was, that the given lines should be used.
Message 20 of 24
michallach81
mine is just another tip, will work for certain workflows.
Michał Lach
Designer
co-author
