We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Help with Holes
Help with Holes
jeffescott
Advisor Advisor
Help with Holes
jeffescott
Im hoping this is an easy solution.
I would like to countersink a hole.....but I want the top of the countersink to be 2mm lower than the top of the hole....
That way the top of the screw will be 2mm below the top of the surface when installed.
Just can't find a way to do this.
Component: Slip Pad:1 Feature: Hole3
davebYYPCU
Yep.
Edit extrusion to 3.6 high.
After the holes,
extrude top face 2mm > Join.
Might help....
jeffescott
sweet thanks alot
johnptc314159
here i extruded the top surface   by 3mm, still need to remove 3mm from bottom 🙂  maybe a little different
davebYYPCU
So you Edit Feature, select the 1st Extrude.  the Distance is currently 5.6mm,
set the new value as 2.6mm.  (5.6-3)
Might help....
