Help with cutout design on a sphere?
ZiMMeN
Message 1 of 25
ZiMMeN
Hi all heroes!
I need help to make a design cutout on a Sphere.
and then I would like to make the sphere in to 4 different pieces, something like attached photo.
Replies (24)
Message 21 of 25
rushabhthakkar_910
@ZiMMeN. I want to add something here...
Can you be specific in your Original Post in Future ...?
See, I know we all change our minds. But as soon as someone tries and solves your Question, you post Good Work, but that's not what I want.
And post another Query ..
Please be specific as to what you want.
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 22 of 25
davebYYPCU
That’s the easy bit, I just traced the Canvass in my first version, you have not mentioned the pattern format, and Fusion works with geometry, not graphics.
you only need the dxf, making your other patterns into a ball, is where the Fusion work lies.
within reason, change the source geometry, and the file will update to the new pattern.
Now that you can see my sketch 4, make a parametric outline template, and cut your patterns with it, no need to make the ball, but I would need to see the finished one, for cut alignments, hardware regions, and proportions.
@rushabhthakkar_910  Your comment is not fair,
I asked questions for my working boundaries,
threads like this should be fine tuned, usually quite hard for original posters to tell us with absolute precision - some don’t / can’t supply their data, but it is easy to adjust in little steps.
@ZiMMeN Make some and send a picture, please....
Message 23 of 25
rushabhthakkar_910
@davebYYPCU , I don't have any issues with @ZiMMeN giving information in bits and pieces..
But I am just saying it is Good if the OP gives the Information in the Post itself.. I mean here @ZiMMeN is constantly changing the Designs (No issues). But could have easily posted it in the Original Post itself. That help is needed in these many designs...
Thanks and Regards,
Rushabh Thakkar.
Message 24 of 25
g-andresen
without words
günther
Message 25 of 25
ZiMMeN
@rushabhthakkar_910
@g-andresen
Ok next time I will be more specific about what I want.
Post #1: I need help to make a design cutout on a Sphere. (Did mention that I need to cutout a design on a sphere)
Did mention that I would like to cut the sphere in to 4 different pieces (see picture as ref.)
@ZiMMeN wrote:
Hi all heroes!
Post #3:  Did show a real existing object with a pattern cutout on a sphere
@g-andresen wrote:
please show a real existing object
günther
Post #9: Contributed with a picture of one of the patterns I bought to be able to use without being accused of theft!
@ZiMMeN wrote:
Huge thnx, but not exactly what I need.
If you see my attached image you will understand how the 4 segments of the sphere is.
The four of them will be joined together to bring them together into a sphere.
So I need a way to put patterns like this (just bought a bunch) see the picture I attach.
This pattern should be across the entire sphere so that they join at each segment.
without words
günther
