That’s the easy bit, I just traced the Canvass in my first version, you have not mentioned the pattern format, and Fusion works with geometry, not graphics.
you only need the dxf, making your other patterns into a ball, is where the Fusion work lies.
within reason, change the source geometry, and the file will update to the new pattern.
Now that you can see my sketch 4, make a parametric outline template, and cut your patterns with it, no need to make the ball, but I would need to see the finished one, for cut alignments, hardware regions, and proportions.
@rushabhthakkar_910 Your comment is not fair,
I asked questions for my working boundaries,
threads like this should be fine tuned, usually quite hard for original posters to tell us with absolute precision - some don’t / can’t supply their data, but it is easy to adjust in little steps.
@ZiMMeN Make some and send a picture, please....
