Help with creating a Mandolin top
PvdBos
Message 1 of 27
PvdBos
Hello, I want to create a Gibson junior Mandolin Top from 1920 The top is broken so I will make it by my self.
But I have some help with this.
I have create some lines so that I can fill it up with the patch tool but this will not working.
Am a hobbyist so for my it's a challenge
can someone help me with this!
I have my fusion file attached.
thanks
Replies (26)
Message 21 of 27
TrippyLighting
I think for intended purpose that is a very nice way to model this!
No need to waste time to model perfect surface transitions, when the end product is going to be machined directly on a CNC machine and then sanded.
Message 22 of 27
PvdBos
Thank you very very much for making of the Mandolin top. I can now create G-code for my CNC machine.
Message 23 of 27
matthewrjacobs
Thanks Peter.  I certainly borrowed a lot from your techniques.
It's close enough,  but I like to get the models as close as I can to the final product
Message 24 of 27
matthewrjacobs
I would double check everything before you start cutting wood.  I used an F5 Fretboard to help model the flat part. not sure if the FB width and scale length are the same for the A models,  but it's probably close enough.
Also, do you plan to refine the top by hand, or are you going to just slap it back on the body.  if you are gong to hand finish, then what I gave you is probably OK.  if you are going to just glue it to the body you should probably refine the inside surfaces more. otherwise it will sound like poo.
Finally,  you'll need to make sure the FB projection at the bridge is correct, and adjust the body accordingly.  you'll have to look online for some specs, but my guess is ~3/4"
Good luck!
Message 25 of 27
PvdBos
 And the Mandolin top milled and looks almost the same as the original.
Thanks all.
Message 26 of 27
matthewrjacobs
Very Nice!  I'm glad it worked out for you.
What species of Spruce?
Message 27 of 27
PvdBos
I don't know, it's to make for violin top but it's about more than 10 years old
