Help with creating a Mandolin top
PvdBos
Message 1 of 27
PvdBos
Hello, I want to create a Gibson junior Mandolin Top from 1920 The top is broken so I will make it by my self.
But I have some help with this.
I have create some lines so that I can fill it up with the patch tool but this will not working.
Am a hobbyist so for my it's a challenge
can someone help me with this!
I have my fusion file attached.
thanks
Replies (26)
Message 2 of 27
TrippyLighting
Could you provide a few photos from different views ?
Have you scaled the canvas in your design  ?
Due to the existing symmetry, usually you would only sketch and model half of it and then mirror.
Message 3 of 27
PvdBos
Hello, I have some photos add to this with some text about dimensions.
I have used the photo Gibson A1 inside.jpg as canvas.
also I have scaled it to 315mm of total length.
Can you help me with this?..
Message 4 of 27
TrippyLighting
I can help, but you'll have to be patient. If this would only be a modeling task this is not at all a beginner project given that you are also trying to math an existing physical artifact.
The photos don't really help, as I am trying to get a better understanding of the geometry where the neck attaches to the body.   Also, please don't attach photos. Images can be directly embedded into a post by dragging them from a folder into the message body, or screenshots can be pasted from the clipboard directly into the message body.
I am noticing that your images are quite distorted (lens distortion).
Message 5 of 27
PvdBos
The neck is attached to the body and the fingerboard is over the neck and the top. 
Message 6 of 27
TrippyLighting
Yes, I know that 😉
What I am trying to get a better understanding of is how the curved top surface transitions into the mostly rectangular surface the neck attaches to. As such, these flat, top-down photos don't convey that information. A few more images from different angles would help.
Message 7 of 27
PvdBos
I have a drawing of a F5, this is similar with an A1. And it has not exact be the same after milling the oversize top it must by hand make it fit.
I hope that this helps for you.
Message 8 of 27
PvdBos
Sorry I have no drawing of this Gibson Mandolin.
Message 9 of 27
wersy
You could make templates.
Message 10 of 27
TrippyLighting
I wasn't looking for drawings. I was hoping for more photos from different angles.
Question: Once you have a model, what do you intend to do with the model?
Message 11 of 27
PvdBos
I would like to restore this mandolin if I have a model that is similar to the original then I will make G-code for it and mill it on my CNC machine.
What for photo's must make and from what for angles.
Message 12 of 27
PvdBos
The Fusion 360 file what I uploaded is on scale of the canvas photo.
The back/inside of the mandolin top is already done.
is only the top/ouside of the mandolin.
Message 13 of 27
TrippyLighting
I took a screenshot of a model I had. Obviously not a mandolin, but another string instrument with similar construction.
I am interested in one or more pictures of how that area circled in red looks like.
Message 14 of 27
PvdBos
is this what you mean?
Message 15 of 27
PvdBos
The finger board is glued on the neck and the top of the body
Message 16 of 27
PvdBos
is there anyone who can help me make a model similar to what I posted at the beginning Gibson A1 Top v16.f3z
If it's just a little bit like it so I can adjust it.
Message 17 of 27
PvdBos
Message 18 of 27
TrippyLighting
That is a good photo. Tells me exactly what I want to see.
I am attempting this using T-Splines, btw.
Message 19 of 27
PvdBos
I don't know what you want to see
Message 20 of 27
matthewrjacobs
I took a stab at this over the weekend.   Used your canvas,  but pretty much started from scratch.   It's a bit down and dirty and the surface transitions could use some tweaking.  Also, the inside "carve" is pretty crappy, it was quickly modelled.  to do it correctly you'd need to build the inside surface similar to the outside surface.
