With lots of help from this forum I have created an assembly (front binding) that works well.
I have to create a second assembly in the same file. It contains a grounded component (pin die) that is not included in the first assembly (front binding), a mating component (pin shape) that is not included in the front binding. This works fine.
But the two assemblies are over top of each other. This isn't a problem because i can turn of visibility as required.
The problem is I would like to connect a component that is included in the front binding left bent arm, in the pin die assembly. This does not work out....I suppose I need a new instance of this component???? But of course I have no idea what a new instance is, or how to obtain it...
I would be grateful for any help.
