help uploading solidwork file onto fusion 360
trying to upload solidwork files onto fusion but as soon as i try to upload assemblies it gives me failed
its drawings done by someone and i need to use them to get work done
jhackney1972
The ability to upload certain files depends on your license type.  Take a look at the website (scroll down on the page) to see the formats supported by each license.  Is this your issue?
John Hackney, Retired
i bought the 3 year lisence on fusion 360
jhackney1972
So if Fusion 360 is registered correctly, if you go up to the top right hand corner and select the "?" and then "About" you should see Active Plan: Fusion 360, Subscription.  If you do, then please zip up a sample file you need translated and attach it to your forum post.  Others on the forum will try and help you out.  To attach the zip file, look at the second graphic.
TheCADWhisperer
@Anonymous wrote:
1. trying to upload solidwork files onto fusion but as soon as i try to upload assemblies it gives me failed
2. its drawings done by someone and i need to use them to get work done
1. You must upload both the *.sldprt files (parts) and the *.sldasm file(s) assembly and sub-assemblies.
2. Drawings in SolidWorks are *.slddrw files, I have never heard of translating *.slddrw files in Fusion 360.
https://youtu.be/uxg9cLscVPI
Can you zip and attach the entire folder here for testing?
