Help to build domes over curved body
3 REPLIES 3
diarcosb
260 Views, 3 Replies
Hi guys i need a simple design of a plane top dome with mini domes over it's surface.
i create the main body, but i tried to project circles over the surface but then i realized that circles makes cilinders, so i would appreciatte your help to make this,
sorry for my bad english.
3 REPLIES 3
TheCADWhisperer
in reply to: diarcosb
Step 1. Start Over.
Step 2. Turn on Capture Design History.
Step 2b.  Attach new file here for Step 3 and 4.
dsouzasujay
Hi @diarcosb
As @TheCADWhisperer suggested we need to use Parametric Modelling.
Also few more things to add,
  • Insert the mesh files to the origin.
    • 'Insert Mesh' and Hit on 'Center'
  • Fully Constrain the Sketches, Add dimensions so the blue lines turn black
Creating a sketch on a surface is not possible, but it can be achieved by creating a plane at an angle.
Created below video: Hope it helps
Screencast Video: https://autode.sk/3hAnYQF
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
diarcosb
thank you so much!
Technology Administrators
