I'm trying to make a 3mm thin mask from a scan of a head that I can 3D print - like a Mardi Gras mask. I have tried and failed to do this in many ways. With the mesh I've made a copy at 95% of the original, positioned behind the original with the intent to then combine them into one mesh. I couldn't find a way to do that. I converted the mesh to a surface and tried Thicken, but that gave errors. I converted the mesh to a BREP and tried Shell, but that gave errors. After watching some tutorial videos I tried to use Create Mesh Section Sketch and use them to create some BREP parts that I could then degrade to a mesh and combine with the existing, but I failed to find a workflow that worked.
I have done a brute force on this by creating the BREP and then cutting out sections of it with Loft to get a kind of workable solution, but it is so inelegant. It's like a face on the outside of a cylinder, not really a mask at all.
I'm at a loss on how to proceed with this. Any ideas are appreciated. I feel that I must be missing some key understanding here.
I'll attach my sample file to this post.
Jim
