Help setting up static and nonlinear static stress simulation in Fusion360 simulation.
- Mute
- Permalink
- Report
Hi all,
I hope you all had a great new year!
I'm currently developing a foldable backrest for a cargo bike, and therefore I'm trying to validate if the construction is strong enough.
I'm new to the simulation environment and I'm not sure how to set constraints and contacts right.
The backrest is attached with two custom "aluminum shaft clamps" to the rack of the cargo bike and allows the backrest tube to pivot with self-lubricating bushings, a cam lever, and two custom "aluminum pivot arms". The backrest is a Ø25x2mm aluminum tube.
The right alloys are still unknown, so right now the custom CNC parts are in 6061 and the hardware is in default steel.
I don't know the right forces that a passenger would affect the backrest with, but I have tried to run a test with 300N/30kg.
I would really appreciate it if somebody could help me with some guidance regarding mesh setting, constraints, and contacts.
Best,
Frederik Sølver
