Does physical material affect modeling ?
gamelife4dns
gamelife4dns
I mostly make stuff from "solid" and "surface" environments. I never took care about material (steel by default). Now I realize that there is a "plastic" environment witch seems very similar to the "solid" one.
So, does material affect modeling ? (I guess no)
What is "plastic" environment for if Fusion doesn't care about material when modeling ?
Thanks.
Steve
g-andresen
take a look at the Plastic Rules
günther
TrippyLighting
@gamelife4dns wrote:
I mostly make stuff ...
No, you model stuff 😉
The plastic environment is aimed at folks who actually make physical products using (mostly) plastic injection molding.
If you manufacture things, then topics like split lines, draft etc. need to be considered when modeling right from the beginning. The keyword here is design for manufacture.
gamelife4dns
I model stuff, indeed 😉
Thanks.
Steve
