Help.. Rotate body 3D Part 1
fishtruk
fishtruk
I'm playing with Cam on the 3D Part1 example.  I want to machine the top of this part. The way it's sitting, the part is machined from the front. How do I rotate this object about an axis so the machining is done from the top?
Thanks!
fishtruk
Nevermind!   it's in the MOVE section
carl_bass
You can model in any orientation you want and there's no need to move it. When you do the CAM setup, just choose Z from the exisiting model. You can either choose an edge to indicate the z direction or chooose a face perpendicular to z
https://screencast.autodesk.com/Main/Details/8fbce058-6dff-4838-8b21-3ea834ebb756
