Best way to prepare part for machining?
I've designed the attached part that I plan to maching using a Tormach CNC miller. I'm having trouble setting up a clearining strategy that doesn't collide with the stock. The stock is a 4"x4"x2.25" aluminum block. I plan to do a 2.5D milling process. I'd like to clear the front side of the piece and then do a 3D contour around the back and sides. However in my setup, both adaptive and pocket clearing collide into the stock. I'm designing for use of a 3/32" diameter, 1.5" length ball end mill. Is the tool size the problem?
BrettWright
Hi Michael,
Thanks for submitting your question here on the forums.
I think though based on what i see, i need to get your over to either our CAM Forum, the Inventor Forum or the Fusion Forum depending on if you're using Fusion, or if this is just an Inventor file that you're working with. (i can't tell based on the attachment)
The CAM Forum is camforum.autodesk.com
The Inventor Forum is http://forums.autodesk.com/t5/inventor-general-discussion/bd-p/78
The Fusion Forum is http://forums.autodesk.com/t5/fusion-360/ct-p/1234
If you can tell me if you're using Fusion or Inventor, I'd be glad to move this post to the right Forum, or if you want feel freel to just hit the right link above and cut and paste your question into the correct forum.
Let me know either way please.
Brett Wright
Thanks for the response and offer to help. It is built in Fusion.
Sent from my mobile device
Bud_Schroeder_ADESK
Thanks Michael for letting us know. I'm going to move your question to the Fusion forum where the Fusion users can jump in to help you out.
Thanks again for letting us know and hope you are enjoying Fusion, it's an amazing product.
Bud Schroeder
AutoCAD Customer Council Beta Programs
Autodesk Inc.
Join the AutoCAD Customer Council Beta Program.
