Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Help: problem with 2D views
4 REPLIES 4
416 Views, 4 Replies
I have completed the desing of an assembly with several components and now I would like to start putting in place 2D drawings of individual piece parts, but when I try to create a sheet with a base view, then the software always returns me the base view of the whole assembly even if I select the single component as reference.
What am I missing? How can I achieve a 2D base view of a single piecepart of an assembly?
Many Thanks
Enrico
4 REPLIES 4
SaeedHamza
Go to the browser and right click the component you want to create a drawing from, then click on Create Drawing
Regards, Saeed
zhixin.ni
There are two ways to create the 2d view of a single component in an assembly.
1. select the component node in the design file's browser, launch "Create Drawing" command.
2. In the drawing, after a base view is placed, go to the component's node in the browser and suppress others.
Please let me know if it still cannot solve your issue.
Regards
Regards
Nick Ni
in reply to: SaeedHamza
I did try but it did not work. I cannot understand why, but when I create the base view I always see all components.
That is why I did posted the question.
Any suggestion?
in reply to: zhixin.ni
I did try it NIck but it does not seems to work.
Maybe I am doing dome stupid mistake. It seems to be a trivial procedure but I cannot understand why it does not work.
