Help please. issues with uncreasing and warning of edges/faces crossing.
I am learning Fusion and got stuck at 360 for Designers | Part 2 / Lesson 23: Shape Generation | part 9.
I tried to remove the crease as per instructed, however at my desktop it behaves differently.
I believe I have followed every single step from the tutorial.
I also cant finish form as it would gives a warning "edges or faces may be crossing"
I have attached some picture and the public file.
Can anyone please help to explain whats going on in plain language 🙂
Thanks in advance.
https://a360.co/2wJoDYm
subashchandrabose2003
that happens when you done wrong in previous step . make sure you make correctly
( also mark as solution i you like it or click the like button . it will also help me )
subash chandra bose.A
edit the form properly and carefully  because edges or faces should have crossed each other . And
i can't perview you a360 file. i mean  i can't see the full body as you  showed in your attachment
 ( also mark as solution if you like it or click the like button . it will also help me )
    thanks
TrippyLighting
I've explained this just now in another thread where a user has the same problem and I've seen this exact behavior before. There is no user fault here. To a degree I believe there is a bug in Fusion's modeling code that deals with creased T-Splines.
However, creasing is also not a good modeling technique among several other incorrect techniques this tutorial teaches.
I linked to 2 videos in this thread the show how to fix things and outline problems in the tutorial.
Well I am quite sure its not the fault at my part, I followed every single step as I learned. I always pause the video in the middle and do whatever it shows everytime.
I thank you because I was also not aware of this. Thanks I think even I have experienced this before maybe I have left it unconsciously
