building around a 3 D dimension reference sketch
Message 1 of 1
I have a question about the properties dialog box of each body in fusion 360. Is there a way to get a total weight as well as a weighted parts list of all components or parts of the whole assembly? Is it as easy as imputing the weight per ft. of each part or however each specific part's weight is determined? for example plates are lbs. per square ft. or lbs. per ft. for tubes and so on. How can I get this done? Also, I want to know if I can define a cubic meter of volume I want to build around, so is there a way of defining say 81 cubic meters of space that is just considered as a reference volume?  Then build a frame for that cubic volume and get the weight for the frame?
Replies (0)
