Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Help parameters mm to units
11 REPLIES 11
Message 1 of 12
2765 Views, 11 Replies
 Is it possible to convert mm to units ?
I'm measuring the length of a line (100mm)
Length/12/2
And the result is 4,1666 mm and I would like it to be translated and rounded to 4 units
11 REPLIES 11
Message 2 of 12
Phil.E
It's really hard to interpret what you are asking. We need more details. Images help, also more explicit steps would help.
Despite that, I will attempt to answer what I think are your questions. In Parameters dialog you cannot change units. You can however, type any unit into a dimension. For instance, while working in mm you can enter "2 in". Since you are working in mm, the display will show mm, but the distance will be 2 inches absolute length.
If you want a parameter to be 4 instead of 4.167, just enter 4 instead of 100/12/2 as the expression.
I hope that helps, but without more information it's really hard to tell what you want to do, and what your actual question is.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 3 of 12
in reply to: Phil.E
I am trying to make some wood finger joints, that hopefully will be driven by the "length"
Message 4 of 12
Phil.E
Got it. Here is the solution:
User parameters can be unitless. Just divide by 1 mm (or what ever unit you are in) to get a unitless result.
Use that in a pattern. This is a simple version of what you need.
Let me know if this helps.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 5 of 12
in reply to: Phil.E
I'm so impressed awesome support 🙂
I really love to learn some more about what the parametric is capable of doing, is there a list of commands somewhere or other resources you could point me to ?
Message 6 of 12
Message 7 of 12
To round, you put your current expressions in parenthesis, and prefix 'round'. This will round to the closest whole number. Alternative you can use 'floor' to round down to the nearest whole number, or 'ceil' (as is ceiling) to round up to the nearest number.
So your expression would look like:
round(length/width)
Let me know if that works for you!
Niels
Message 8 of 12
Phil.E
@Anonymous You are correct, thanks for explaining that.
Here is the learning page that explains the parameters dialog.
http://fusion360.autodesk.com/learning/learning.html?caaskey=caas/CloudHelp/cloudhelp/ENU/Fusion-Form/files/GUID-76272551-3275-46C4-AE4D-10D58B408C20-htm.html
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 9 of 12
istvan_palotai
in reply to: Phil.E
This is awesome
Message 10 of 12
@istvan_palotai
This is a professional forum.
Can you explain your issue in professional language (and illustrate with pictures/actual Fusion *.f3d file)
When I was in HS (50 yrs ago) this topic (how to handle units) was taught in math class.
Message 11 of 12
It is still not possible to refer to a variable for the number of pieces in any pattern.
just like this: Quantitiy: ( ( d287 / mm ) / 2 )
If you determinate a dimension like this: Length WORKING
Parameter table: Length : 255/2 +Length2/3 mm  WORKING
It will work ! Fine
But if you create a NO UNITS parameter with an expression of: Length/2 It will not support the Length variable.
Message 12 of 12
@istvan_palotai
You have to cancel out units - just like in HS (and College) math classes.
The instructor (at least in the classes I took in the last century) were always emphasizing to handle your units.
You would not pass the class if you did not properly handle units. (I took a lot of math classes.)
Can you Attach example *.f3d class.
I have always taught students to write out their equations (including units) in pencil before attempting to enter into CAD software.  (I taught several different CAD softwares.)
