Help needed - Lego Spike Motor Design
abdelhalimwahid
Message 1 of 10
abdelhalimwahid
I want to design a part like lego compatible part, so I need to design that 2 holes with space between them which is kinda shows that outer cylinder of the hole on the other side.
f
Replies (9)
Message 2 of 10
TheCADWhisperer
@abdelhalimwahid
Can you File>Export your *.f3d file of your attempt to your local drive and then Attach it here to a Reply?
Message 3 of 10
etfrench
Here's one way to make the pegs which can also be used to cut the holes:
(view in My Videos)
ETFrench
Message 4 of 10
abdelhalimwahid
Here you are,
Message 5 of 10
abdelhalimwahid
how can I cut with revolve tool?
Message 6 of 10
davebYYPCU
Its in the pull down menu.
Might help....
Message 7 of 10
abdelhalimwahid
but it still not doing the shell for the hole
I need to make a shell for the hole on the top face( the one between the two holes)
Message 8 of 10
davebYYPCU
How does Revolve Cut and Shell, have anything to do with
Extrude a tube?
Message 9 of 10
TheCADWhisperer
@abdelhalimwahid
Are all of your sketches fully defined?
Do you see any blue lines or white dots in Sketch9?
Message 10 of 10
abdelhalimwahid
All the Lines are blue
