Help moving work between Projects
tgford58
tgford58
I accidentally made a drawing and dimensioned print in a Project Folder that is not my main storage location.  Following a search result, I opened a Team and moved the file there.  How do  I move these files to the correct location?
I apologize if this isn't the correct forum.
tgford58
I was able to get the drawing by exporting and then importing to the right location.  The 2d dimension drawing, not so much.
jhackney1972
If you export the 2D drawing, the relate model, will be exported along with the 2D drawing as an F3Z file.  You also may want to try the Move command from the Data Panel.  This can Move files from one Project or Folder to another within your Team.  Simply right click on a file in the Data Panel, select Move, and this dialog will appear.
John Hackney, Retired
