Hi
I have so many project folders:
In the first picture I have stacks of projects that I have done, and some times I wish I could archive alot so I can see the sun through the trees.
As you can see all the projects are in a main folder called "Ians Original Projects"
It would be good if I could make a new folder called "Ians 2024 Projects and be able to select that and start projects there.
Can this be done and if so could you direct me how to do it.
Regards
Ian
Link copied
