Help! I need to inverse this lock
I'm trying to make a another piece that inverted to the one I made, so I can lock them together, could someone help?
davebYYPCU
Your question is not real clear,
Is this what you mean?
I have selected both bodies and use the Mirror Command, with the bottom face to get that result,
I have redone the object, as I would do it,
use the file origin,
will leave you to dimension the sketches,
sketches are unfinished until all articles have turned black.
Might help....
Thanks for responding
Sorry, Im having a hard time explaining it, but what I'm trying to do is make the two shapes snap together so I need to design a "male" and "female" piece. I can make the "male" end but not the "female" one.
davebYYPCU
Closer?
Outside one will hold down the inside....
I'm trying to make a "female" version of this circle so the can lock in place, I've attached to different file to help illustrate what I mean.2
