[HELP] Fill gap between two bodies, to combine them and join them
oluwadarasimi.paiten
Hi, I need fill gap between two bodies, to combine them and join them.
Using loft I did not succeed, the two faces are in parallel, and without any space between them.
I already solved creating 0.1mm offset from profile 2, and extrude to join to profile 1, but is so weird. Any quick solution for this?
I read this, but using patch workspace, I try use, but doesn't work as well. I want a solution only with model workspace if it is possible
https://forums.autodesk.com/t5/fusion-360-design-validate/joining-filling-between-two-surfaces/m-p/7...
See the prints below:
cant loft in 0mm diff and paralel surfacescant loft in 0mm diff and paralel surfaces
sanket223.patil
Can you export your file .
Sanket Patil
Mechanical Engineering
Expert Elite
dghylin
Have you tried the 'Combine' command?  If the two bodies are touching, that should work....
TrippyLighting
That might be true but based on these screenshot it would still be a pretty bad idea.
dghylin
Well, from his posts, he didn't like the idea of separating them and lofting between them so....what is(are) the other procedure(s) available to him??  Probably wouldn't work for him but I guess he could create 'selection set'.
And, If you can tell from the screenshots what he's after, you're much better than I am, of which I have no doubt......:)
Sorry I can't. But the simple example is make a hole in a surface, and how do you fill the hole, without use extrude methods.
