HELP Error Window won't stop popping up
5 REPLIES 5
tranq006
217 Views, 5 Replies
Hello All,
This stupid error window saying "fusion quit unexpectedly" keeps popping up continuously when Fusion is open and every now and then even when Fusion is not open. I have restarted my computer already. How do I get this to go away?Screen Shot 2022-06-03 at 12.03.03 PM.png
5 REPLIES 5
jhackney1972
in reply to: tranq006
You did not say what your operating system was but if it is a MAC, you need to probably take a look at this Forum post.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Have a look at this Forum Post..!!
(https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/An-...)
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
And this too..!!
(https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fus...)
Thanks and Regards,
Rushabh Thakkar.
This seems to have worked. Thank you
I am glad it helped you out..!!
Thanks and Regards,
Rushabh Thakkar.
Technology Administrators
