Help Editing Face!
Help Editing Face!
Help Editing Face!
Not sure if this is the best way to go about this or not but I'm trying to close the back of the attached body but I'm not having luck. I'm able to use the edit face feature under surface to get half way there but it looks sloppy and I'm thinking there has to be a better way. I've attached the .f3d file for review if anyone is able to assist. Thanks in advance!
davebYYPCU
Like this?
Create a sketch on the lower face of the boss
Project > Intersect > Body select your body and OK
Extrude > Join > Set depth, The select the 3 profiles to make a floor with hole in it.
Might help....
laughingcreek
Have you considered re-creating this entirely in fusion?  It would be extremely simple to do, and then you would have clean geometry moving forward.
Thanks for the help! I actually figured it out last night (or at least another way) but I appreciate the insight. Have a great day.
