Help designing Weight Bench Pad
deza992450
deza992450
Hi everyone.
I'm a complete newbie to fusion 360 only just downloaded the trail version, I've been using PRO100 to design everything I've ever built which is simple designs however I want to design a new weight bench and need help with how I go about designing the seat pads. photo for reference. Please and thanks 🙂
Warmingup1953
Do you have a good photo face on without distortion? Will you simply plywood on a CNC and upholster that?
TheCADWhisperer
@deza992450
Can you File>Export your *.f3d file of your attempt to model the geometry to your local drive and then Attach it here to a Reply?
Have you gone through the built in Tutorials?
Can you sketch a 800mm Construction line Vertically from the Origin?
