Help cutting unique slot
carterszydel5228
carterszydel5228
I am designing this bolt action pen, and when I make this pen I will cut out the slot for the bolt on a mill with a rotary table, so the slot wont cut straight down, it will cut down with the profile of the 'body end' piece.
TheCADWhisperer
Solid Sweep (with Cut)
@carterszydel5228
Also, not sure if you intend further operations here - but just to be sure - this thread will not work as is.
carterszydel5228
I am having trouble with the solid sweep feature because I have never used it before, and for the threads I do not know how to align them.
TheCADWhisperer
@carterszydel5228
Alignment is not really the issue (that can be solved with a couple of Joints). The real issue is that the thread is offset from the end of the cylinder. There is no way for the threads to engage.
carterszydel5228
I now understand what you are saying about the threads, when I try to change the female threads on the 'body' to full length it gives me an error.
jhackney1972
You have been given the best method of cutting the pen slot but you probably are wondering how to get the Solid Sweep path.  In my attached video I outline one method.  I hope it helps.  The model I used in not yours just one I created to demonstrate.  It is attached.
John Hackney, Retired
carterszydel5228
thank you this will help a lot
