Combine Command Question With Inserted Components
richardsalzman
richardsalzman
I am trying to use the combine command with and use the dark gray rectangular shape(top arrow) to cut a profile into the round cover beneath it (bottom arrow).  The cover was inserted into this drawing.
The combine command will not let me select the cover as a target body?
Is there a way to do this?
Richard
jeff_strater
correct.  You can only make changes to the components and bodies in the active design.  Inserted components are read-only.  If you have a commercial license, you can do Edit In Place, which allows you to edit external components in the context of the higher-level design.  That should work in your case.  I think Combine is supported in EIP, but I haven't tried it myself.
Jeff Strater
Engineering Director
jeff_strater
yes, Combine does work in edit in place:
(view in My Videos)
Jeff Strater
richardsalzman
Thanks!
