Help creating flat pattern to export a dxf from a mess of a drawing.
taicher8
Message 1 of 8
taicher8
I received a file that is a mess.  I need to create a flat pattern for body 27 to be able to cut it out on a laser table so I am trying to create a dxf.  I am unable to get the body to unfold.  Any cheats or ways to make it happen with destroying the drawing so it still matches with body 1?
Replies (7)
Message 2 of 8
taicher8
Here is just the body I need flattened for a dxf.  Any ideas?
Message 3 of 8
kacper.suchomski
Hi
Try exporting this particular body to step format and importing the single body into a new file.
Kacper Suchomski
Message 4 of 8
taicher8
I tried that as well as re drawing just that body and still won't let me convert to sheet metal.  This is the second version of this and the first version worked great.  Still trying to work on it.
Travis
Message 5 of 8
kacper.suchomski
This element has incorrect geometry. Look at the transition between the flat area and the arc - they're not in the same place. Sheet metal modeling requires precision and adherence to many rules, which were violated here.
Kacper Suchomski
Message 6 of 8
g-andresen
1. As @kacper.suchomski  points out, the problem lies in the lack of tangentiality in Sketch 1
2.
günther
Message 7 of 8
TheCADWhisperer
This is relatively simple geometry - badly done.
Do you still have communication with the original designer?
A couple of questions that I have would clear up the Design Intent.
Message 8 of 8
taicher8
I am just going to clear up the design so I can start fresh.  Thanks for the advice.
