Help! All my object colors changed
JetForMe
JetForMe
I have six components in my design. They had assigned material colors. I was in the middle of a sketch, trying to undo some mistake, when all of a sudden I was looking at my model and each component has a unique color. If I open the appearance dialog, they revert back to the correct materials, so I'm pretty sure they haven't changed. But I can't figure out what display mode I engaged that's making each component a unique color.
What did I do?
Thanks!
MacBook Pro, PCNC1100 Series 3, Slant-PRO 15L Lathe, Custom AvidCNC-based 4x9' CNC Router w/24k 4.5 kW HSD Spindle & Teknic SDSK Servos
JetForMe
Ah I found it. "Component Color Cycling" got enabled by accident.
jeff_strater
Most likely you hit the "n" shortcut key, which toggles this mode.  Glad you got it figured out, though.
Jeff
Jeff Strater
Engineering Director
cool i was panicking too
that happened to me too, thanks for the "n" shortcut explanation
