problem with drawings "shaded with visible edges"
hello
I have a problem with my exploded drawing, it is a drawing from animation.
macmanpb
Hi Tom,
your description was a little short but i think you have components in your drawing that you want not see.
If you start to create a drawing from a design or animation this dialog appears.
Uncheck "Full Assembly" and you can select the components that you really want into your drawing.
Hope that helps...
scott.price
Hi Tom -
Thanks for posting this, looks like a bug. Are you seeing this behavior consistently?
Best,
Scott
Yes it happens all the time when i try it again
Verstuurd vanaf mijn iPhone
scott.price
Thanks Tom -
At a quick pass I can't repro the issue
Would you mind sending me the Fusion 360 Archive File (.F3Z) - You can download this by clicking the "i" Drawing thumbnail in the Data Panel (at the left), selecting "Open details in A360". In A360 at upper right there is a download arrow icon, here you should be able to select Fusion 360 Archive.
If you email that to [email protected] I can look at the file and try to get an idea of what's going on.
Best,
Scott
