Helical path copy feature
ksAZ3XE
Message 1 of 1
ksAZ3XE
WE NEED THIS FEATURE
theres been numerous post the last 8 years about people needing a feature to do this, copy a body or component along a helical path, make holes on a surface in a helical path.
and all we have is many workaorunds that doent even do it properly.
come on man please add this, it should be so simple... i was using Inventor 10 years ago and it had this function natively..
it should be as simple as adding a z value to the circular pattern..
or angle value to the along path funcktion
its absolutely infurriating to make a spiral staircase this way... i can copy/move the step one at a time to sorta get it to work, but if i need to change something its back to the begginging again...
this is such a basic feature that is used all the time in manufacturing and Fusion is such an unserious program if they STILL HAVENT INCLUDED THIS AFTER PEOPLE ASKING ABOUT IT FOR 8 YEARS!!!
@ksAZ3XE -this post has been edited due to Community Rules & Etiquette violation.
Replies (0)
