Having trouble reusing components in other projects
salesMUBBN
salesMUBBN
I have been creating enclosures for 3D printing and wanting to set up a generic base and lid I can use as starting point for new designs but having trouble using pre-designed components.
What I have been doing is create a new project then select the previous project and insert into current design.
This works ok but I cannot make changes to the bodies. When I try to "Break Link" I get error "The selected instance has some essntial dependant instances"...
Also, does anyone know of a video tutorial that covers the workflow for properly handling this reuse of components in other designs.
johnsonshiue
Hi! Here is an article describing how to reuse a preexisting design.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-Insert-a-Co...
Many thanks!
Software Test Engineer
salesMUBBN
I get the error I mentioned in my post when I try this.
