Help me to draw a Dodecahedron using sheet metal.
jeremy_draper501
jeremy_draper501
I have drawn this Dodecahedron, please see attached file
I would like to now draw it using sheet metal so that I can unfold it into a nest, what would be the best method to use ?
davebYYPCU
You need a Sheet Metal Rule, that guides you with thickness and bend behaviour.
With that in mind you create an Offset surface body, Thicken and then flat pattern.
Warning - won’t be exactly the same as the current one.  Huge pitfalls / learning curve ahead, figuring which edges to bend or not.
Might help....
Warmingup1953
Screenshot 2023-03-31 144812.jpgScreenshot 2023-03-31 144733.jpgScreenshot 2023-03-31 133703.jpgFor what purpose?..are you really going to laser cut sheet steel say two pieces then fold and weld?
I left one Petal bent at only 60 degrees not 63.4 so you can see the sheetmetal workings
jeremy_draper501
Hi
Thanks for taking the time to model and share the file, I have been through it and drawn it myself.
I was just going to wire edm the shape and bend it up on a fly press.
Im just fascinated by polyhedra.
davebYYPCU
Only half a job?
fernanda_medina_aguirre
Share Wire EDM Feedback
I'm Fernanda, a Manufacturing specialist focused on the implementation of manufacturing solutions. At Autodesk we are always looking for ways to make our customers’ experience great.
We would love to hear your thoughts about Wire EDM.  Please respond to the following survey, which will help us to understand your current manufacturing needs. The survey should take 5 mins or less to complete.
Wire EDM survey link
We really appreciate your time. Your feedback helps make Autodesk even better.
