Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Having trouble modelling a complicated curved surface based on stl file.
5 REPLIES 5
Pahasave
359 Views, 5 Replies
I have a 3d model of a tank turret that is in .skp format (sketchup) which I exported to stl, imported into f360 and converted to brep.
Yes there is a youtube video about creating the Fusion360 logo that I attempted to use but I keep running into errors (https://www.youtube.com/watch?v=XD7HBFlIFMM   Fusion360 was unable to repair the errors no matter how I tried. )
Either way it's too complicated for that method above as the turret has asymmetrical curves and lots of odd angles
I thought of using F360 instead of meshmixer because after creating the basic shape, I need to hollow it, create some parts for it.
5 REPLIES 5
a) Can you File -> Export and share your design
b) Can you create a STP / STEP file instead of the stl file? Might be easier to work with.
AFAIK sketchup only exports triangulated meshes. Even if it exports a .step file it might be a mesh.
Ouch - didn't knew that. Thx for pointing it out.
I can export it in dae or stl. that's all.
etfrench
in reply to: Pahasave
You said you converted it to brep, so export your Fusion 360 file instead of the Sketchup file.  Export it from the file menu: File|Export|Archive file *.f3d
ETFrench
