I have a 3d model of a tank turret that is in .skp format (sketchup) which I exported to stl, imported into f360 and converted to brep.
Yes there is a youtube video about creating the Fusion360 logo that I attempted to use but I keep running into errors (https://www.youtube.com/watch?v=XD7HBFlIFMM Fusion360 was unable to repair the errors no matter how I tried. )
Either way it's too complicated for that method above as the turret has asymmetrical curves and lots of odd angles
I thought of using F360 instead of meshmixer because after creating the basic shape, I need to hollow it, create some parts for it.
a) Can you File -> Export and share your design
b) Can you create a STP / STEP file instead of the stl file? Might be easier to work with.
AFAIK sketchup only exports triangulated meshes. Even if it exports a .step file it might be a mesh.
You said you converted it to brep, so export your Fusion 360 file instead of the Sketchup file. Export it from the file menu: File|Export|Archive file *.f3d
ETFrench
