Having issues shelling an object
dankG2KYJ
Message 1 of 9
dankG2KYJ
I'm trying to shell the bottom part of this body to around 2-5mm or so. I cannot get any value to work correctly. It seems some of the face geometry on the concave side may be causing the issue?
Replies (8)
Message 2 of 9
mavigogun
Those Face Splits and broken Fillets can't be helping- I guess you opted to patch across those features rather than Delete or Suppress them?
Message 3 of 9
dankG2KYJ
This is from a cut operation I did, and the patches were on the tool object, the faces transferred over. I've tried deleting the broken fillets and patching, but I get errors when I try.
Message 4 of 9
mavigogun
I'm kinda surprised the cut was successful.    Consider stepping back to the source part and taking the Delete/Suppress rout.    The cleaner, the better.    Alternatively, you *could* try to offset the face- but I wouldn't hold out much hope success via that angle.
Message 5 of 9
dankG2KYJ
What if I can't suppress those features on the cutting tool? I only have a .STEP file of it.
Message 6 of 9
mavigogun
Then you're left with Deleting all those elements, I reckon.
Message 7 of 9
dankG2KYJ
Then we come around full circle. 🙂 The current model is what happened after the deletion of those features. I guess I'll have to think of some other way.
Message 8 of 9
TrippyLighting
Trying to de-feature imported geometry should be done either in direct modeling mode, or if you've got a timeline already with "stuff' in it you can also edit the base feature of the imported geometry which puts you in a timeline-off mode for that particular part.
This is complex geometry and with your attempts the surface is butchered already to a degree. Can you attache the original step of that dome shape ?
I would try to de-feature the dome shape and make the cutting body from that de-featured part.
Message 9 of 9
dankG2KYJ
I believe this is what I ended up going back and doing. I made new surfaces on the cutting tool to be completely smooth, this took quite a bit of effort. Then there was some geometry from the final cut shape that interfered with the shelling. I appreciate everyone's suggestions!
