Another planetary gear post
Hi!
How do you generate planet/sun/external gear sets in Fusion? I'm looking for a better method than what I've got.
I've been using Woodgears.ca to generate sun/planet gears. firstly by making ring A/spur B pair, then spur B spur C pair. From there I can send DXFs to Fusion, turn on design history, extrude, etc. This workflow does NOT give me an option to add tolerances, Fusion plays with DXF only grudgingly. I find that when I reassemble the extruded gears there's clearly overlap that I can't seem to massage away, so I assume my method is close but no good.
All the tutorials I've found start calculating gear ratios and the next thing I know I'm waking up with drool on my shirt.
If there's a generator add-in (more than the spur generator), that would be awesome. Ideally herringbone as an option.
How do you do it?
