Another planetary gear post
i-make-robots
i-make-robots
Hi!
How do you generate planet/sun/external gear sets in Fusion?  I'm looking for a better method than what I've got.
I've been using Woodgears.ca to generate sun/planet gears.  firstly by making ring A/spur B pair, then spur B spur C pair.  From there I can send DXFs to Fusion, turn on design history, extrude, etc.  This workflow does NOT give me an option to add tolerances, Fusion plays with DXF only grudgingly.  I find that when I reassemble the extruded gears there's clearly overlap that I can't seem to massage away, so I assume my method is close but no good.
All the tutorials I've found start calculating gear ratios and the next thing I know I'm waking up with drool on my shirt.
If there's a generator add-in (more than the spur generator), that would be awesome.  Ideally herringbone as an option.
How do you do it?
etfrench
I use Gearotic to create gear sets as this gives me the diametrical pitch for each gear as well as center to center distances.  This information is all you need to create spur gears in Fusion 360.  You may be able to get the same info from Woodgears.ca.
p.s. Herringbone gears have the same diametrical pitch as a regular spur gear, so you can do the preliminary design with the spur gear add-in.
ETFrench
lichtzeichenanlage
@etfrench: Thx for the hint. I'll check it. I've used FreeCAD with the FCGear add-on in the past for simple stuff. Might be an option, too.
