Having issues making solid from sketch
snaven655
snaven655
I am a newbie to Fusion 360.  I am attempting recreate a part I need to 3d print..  I have a good portion of it sketched.  I have spent days messing with the contraints to try to extrude from the sketch without success.   What am I doing wrong?  file is attached.
Accepted solutions (3)
snaven655
Sketch.ShowUnderconstrained
Under constrained points: 6, under constrained curves: 0
It does not show me where they are...
g-andresen
The profile for the extrusion was in a 3 d sketch and was probably destroyed.
I removed the 3D elements in sketch 1, unlocked the sketch and lifted all elements to the 2D plane.
The sketch must now be dimensioned and completed with further conditions.
(view in My Videos)
günther
snaven655
Thank you!
Drewpan
Look carefully at the results of Sketch.ShowUnderconstrained as it does show you where they are, you need to see
them.
Since you have points that are unconstrained those points will be open circles instead of black circles. Often you just
need a dimension or a coincident constraint to lock them down.
Cheers
Andrew
Drewpan
Can I make a suggestion about your modelling. Sketches should not be overly complex they should really map out the
basics so that you can use the modelling tools to craft the final shape. An example of this might be to create a bar with
rounded ends. I can sketch this quite easily, I can work out the radius of the ends and I can constrain and then simply
extrude the finished shape. Another way and arguably better way would be to simply sketch the bar outline, extrude it
then use the fillet command to get the ends rounded. You end up with the same result but the workflow is different.
Why would you do it this way?
Fusion is modelling software where you create the model first and the paperwork later from the finished model. Using
sketches to craft complex shapes  is more like drafting where you work out the hard stuff first then model it. Many of
the Gurus on this forum will use many less complex sketches to craft a final part because complex sketches can be
easy to break and broken and unconstrained sketches are often the root cause of problems down the track.
By simply fully defining my sketch and then trimming the bits I "don't need" in this simple example, I have broken the
sketch. I now need to go back and fully constrain it which happens often when trying to get my sketch just right. But
what if instead I modify my sketch with the tools instead?
Similar shape, but now when I extrude I will use the tools.
This is less work because I don't break my sketch and re-constrain. I am still using the knowledge I have on what my
shape will look like but when I go to create my engineering drawings, instead of basically copying the sketch, which
is double working, I use measurements directly off my model. My model is the final shape of the part, where as my
sketches could be quite basic.
Cheers
Andrew
snaven655
Thank you for you knowledge and schooling!
