grouping sketches
grouping sketches
mmharris
Message 1 of 8
grouping sketches
mmharris
I highlight 3 sketches , RMC  , then select create group and nothing happens
in the timeline creating a group works and can name etc
but not in sketches?
Suspect another newbie issue.
thanks
Mark
Replies (7)
Message 2 of 8
jeff_strater
your understanding is correct - you cannot group sketches.  Groups today are limited to bodies.
Jeff Strater
Engineering Director
Message 3 of 8
mmharris
why does the software offer that choice if it doesn't work?
Message 4 of 8
jeff_strater
that's a bug, certainly.  Agree, it should not offer that context menu for sketches.
Jeff Strater
Message 5 of 8
jeff_strater
I do not see this behavior, can you record a screencast illustrating it?
Jeff Strater
Message 6 of 8
jeff_strater
or are you referring to "Create Group" in the timeline?  That option exists as well, and does create a timeline group:
Jeff Strater
Message 7 of 8
mmharris
.... the make group command should be grayed out or not show up at all if it does not work.
Makes learning difficult and raises frustration level.
It is very disheartening not to be able to trust the software to function.
which brings me to copying complete sketches  ...
that doesn't seem to work as a highlight and drag
the 9 step process (on forum  autodesk 07-10-2014)   seems to work erratically at best
projecting is cumbersome also
Message 8 of 8
jeff_strater
copying complete sketches is not supported.  I'm not sure what your comment about highlight and drag.  The process for copying sketch geometry to a new sketch is:
  1. select the geometry in the source sketch
  2. Copy
  3. create a new sketch
  4. Paste
The reason why direct copy/paste of entire sketches is not yet supported has to do mainly with the complexities of the sketch coordinate system, and projected geometry.
Jeff Strater
