Graphics problems
Graphics problems
yoshimitsuspeed
Advisor Advisor
Graphics problems
yoshimitsuspeed
Within the last two weeks I have seen a new bug. The first time I noticed it was in CAM when I went to edit an already existing setup and the model disappeared. After panning and zooming I found almost a hole in the cloud that I could see the origin through but it was huge and didn't look normal at all.
Now today I tried to edit a fillet size on another model and when I double click on the existing fillet and the edit fillet tab pops up the model disappears completely and all that is left is the grey background and the fillet size blue arrow but the arrow is not pointing at anything. I cannot see the model, I cannot see fillet lines and I cannot select or deslect the lines. I cannot drag the blue arrow. Usually pushing ctrl shows the selected fillets but here it does nothing. I cannot edit this model and I cannot do my work.
I tried going back to direcx9 with no change.
I deselected and reselected all effects, changed the environment, visual style, mesh display and object visibilities with no change.
Now I cannot machine this part I was supposed to finish today.
https://www.facebook.com/groups/1229995573786339/
Phil.E
After switching to DX9 did you restart Fusion?
Are you on a laptop?
Are you connected to an external monitor?
Can you check the Graphics Diagnostics under the ? help menu? Use copy to clipboard and paste the results here.
Thanks!
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
yoshimitsuspeed
Yes I restarted it
No this is my desktop
[GPU Information]
GPU Device: NVIDIA Quadro 600
GPU RAM: 1024 MB
[Graphics Effects Settings]
Anti Aliasing: On
Ambient Occlusion: On
Object Shadow: On
Ground Shadow: On
Ground Reflection: On
Selection Display Style: Normal
Transparency Effect: Better Display
[Notes]
1. If you see any graphics display abnormalities, updating to the latest graphics card drivers could help resolve them; please check with your GPU vendors to download and install the latest graphics card drivers.
2. The effects could slow down the graphics rendering; try to limit them for optimum performance.
[Limit all effects to provide optimum performance]
Off
Phil.E
Did you check for newer drivers with NVIDIA?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
