Hello, I am currently working with a integrated BOM management software (OpenBOM) that I want to use to generate part numbers. However, it requires the Part Number property to be empty because OpenBOM have designed a block to prevent users from overriding existing OpenBOM generated part numbers. Only after learning this have I found out that all components within my large assembly have their Part Number property already filled and I cannot edit and clear the property at top level. This means I have to go through components individually and clear said property which takes a considerate amount of time for a very monotonous process.
Is there a way I can globally update the components within my assembly so that the Part Numbers are all cleared with a single command?
(See picture attached:)
