How to Thicken a Complicated Surface
jake_resnick
jake_resnick
I'm trying to make a mold for this RC airplane fuselage, I can do Combine Cut from another body, but then I have a lot of excess material.
I want to Thicken it as a surface so a can have a mold with a consistent thickness everywhere, but it just shows an error because the surface is too complicated.
I have attached the file if anyone can give me some advice I would greatly appreciate it.
jhackney1972
I agree, the surfaces are too complex to thicken a surface but you can create a mold using a different process.  Here is a solid mold of the fuselage.  One half is turned off but can be shown if needed.  May not be what you asked for but it is a mold. Model is attached.
John Hackney, Retired
etfrench
Try this:
Offset face excluding flat areas.
Thicken.
Repeat for flat areas.
ETFrench
TrippyLighting
How thick would it need to be?
That is an important detail you forgot to mention!
I was able to shell it inwards of outwards by.1mm 😉
Anything larger, you'll have to offset this surface by surface and re-trim.
jake_resnick
I was able to do that, but I'm left with a lot of excess material. I wanted to just thicken the whole thing so I only have the material I need, but if it's not possible I will just do as you showed.
Thanks so much!
jake_resnick
Ok I will try, Thanks!
jake_resnick
Yes a wanted to thicken it to 20mm or 30mm but I guess that's not possible. I will try doing it surface by surface. Thanks!
