GHOST OBJECTS
GHOST OBJECTS
GHOST OBJECTS
I created a component, and arranged it in a circular pattern.  The copies of the original fit together just fine, but only the original component shows up as a solid.  All the rest are just representations that are  just wireframe looking.
How do I get the ghosty ones to be solid like the original?
graham.goodier
Hi there,
Thanks for posting! If your 'ghost' problem looks like below, where there are several components in the graphics window, that's because only one of the components is active. You can tell when a component is active by the checked dot next to each component like below:Ghost Capture.PNG
If I active the whole assembly like below, you can see the components are no longer 'ghost like' and can be seen as consistent solids:
To activate a component, hover over it's name in the browser and the dot to check will appear shortly after hovering over it.
If this answers your question, please tick "Accept Solution".
Graham
Graham Goodier
Product Specialist
Thanks.  That did the trick.
