Help: Cannot loft 3 profiles
Hi guys
I am trying to loft these 3 profiles here, but I can only 2 at a time. How can I solve this?
Here is a screencast to illustrate the problem further.
Screencast will be displayed here after you click Post.
c12a85c2-d2db-4b5b-bd47-0caba7dc4277
TheCADWhisperer
File >Export and then Attach your *.f3d file here.
Here you go 🙂
TheCADWhisperer
I think the entire model can be significantly simplified, but before I spend time on this - is the Attached corner what you are after?  (I am just trying to understand your Design Intent - the Attached is not really how I would do it.)
Hi CadWhisperer!
Looks amazing thanks a lot.
So the bottom part was actually just a failed experiment. So if you just continue as you did in the top, then that's perfect. That means just making the bottom as you did in the top in the version 1 file you attached, not the version 2.
How did you actually do do it?
