Getting logging error
Hi guys,
I am getting the following error while trying to sign in at Fusion 360:
I have checked the web service log at
  • Windows: C:\Users\***\AppData\Local\Autodesk\Web Services\Log\WebServices.log)
And I get the following error:
2017-04-03T09:44:05.051Z [Fusion360:2680, 4912] [AdWebServices.Session ERROR] Starting logout in server using REST
2017-04-03T09:44:05.052Z [Fusion360:2680, 4912] [AdWebServices.Session ERROR] Failed to logout in server for product a21ba95bec91.1:. Failed to invalidate token in server. Http error: 0. Network error: 0 Unknown error
I have tried a lot of forums and different things but haven´t been able to log in.
Has anybody faced the same problem? What can I do?
Thanx in advance,
Daniel
innovatenate
Autodesk Support
Autodesk Support
Sorry to hear about the troubles.
Could you also share any log files you find in the below directories and upload them to this thread?
C:\Users\***\AppData\Local\Autodesk\Autodesk Fusion 360\Logs
or
C:\Users\***\AppData\Local\Autodesk\Autodesk Fusion 360\***\Logs
There's lots of suggestions to try in this link, have you been through these?
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fus...
Also, do you know if the time, date, time zone, and daylight savings time on your computer are accurately set? The below link has some suggestions you may use.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Incorr...
I hope these suggestions help. Please let me know if you have any questions.
Nathan Chandler
Principal Specialist
Hi Nathan,
Thanks a lot for your response.
Thanks to James.Youmatz support, I fixed this error by deleting the loginstate.xml file located in the Web Services folder (C:\Users\***\AppData\Local\Autodesk\Web Services).
Daniel
