Fusionlauncher.exe new since last update?
Since a while when starting Fusion 360 I see Fusionlauncher.exe
Came this pop-up with a last update?
regards,
Pieter
innovatenate
Autodesk Support
Autodesk Support
Hi Pieter!
Did you mean to post a image? I'm not sure what error you're seeing.
Thank in advance for the clarification.
Cheers,
Nathan Chandler
Principal Specialist
tried to make a screenshot but that is not possible ( tried different ways )
The pop up text ( partly) :
User account control
Do you want to allow this app to make changes
to your device
FusionLauncher.exe
Verified Publisher : Autodesk,Inc.
File origin : Hard drive on this computer
YES or NO
When I started working - december last year- with Fusion 360 there was no pop up
I don't know when it came
I think mid january
I have had contact with Mike Grau Autodesk Muenchen vie Teamviewer
He made some changes on my PC
Maybe this caused starting to pop up
Or the latest updates can be the reason or it.
regards,
Pieter
innovatenate
Autodesk Support
Autodesk Support
Thanks for the update. The dialog box you're describing sounds like it is related to User Account Control settings in the Windows OS.
One way I know you can prevent the dialog from appearing is to modify the settings in Windows.
1. Select Change User Account Control Settings from Control Panel\All Control Panel Items\User Accounts
2. Lower the slider bar to the ‘Never Notify’ position
3. Select OK (Restart if prompted)
There is really no harm with the dialog appearing and then selecting yes to continue launching Fusion 360. If you prefer not to change these settings, it shouldn't have any negative impact.
I hope that helps!
Nathan Chandler
